Civil 3D Forum
FDO Connect to .sid (Aerial photo)
1 REPLY 1
sfore
332 Views, 1 Reply
I've started connecting to Raster (.sid) Aerials thru mapwspace rather than inserting them thru the Planning and Analysis Workstation due to greater control with gray scale and resampling raster and such.  I started noticing after I save, I can't select anything in my drawing.  I was connected to a whole county Aerial .sid file, so i thought maybe if I only connect to individual tiles for my project area which consisted of 9 .sid files, the issue would go away.  It didn't.  I tried typing REA, purge, audit, then eventually I would crash.
Is there something wrong with FDO connections with .sid files thru mapwspace in C3D 2013???
1 REPLY 1
Murph_Map
in reply to: sfore
SID files when loaded with FDO are resources hogs, I expect the raster enginge that dispalys them is taking a while to regen and not waiting before you try selecting anything is causing it to crash. You can try converting them to TIF and see if it works better.
Murph
Supporting the troops daily.
Rail Community
