Civil 3D Forum
Fatal Error when changing Paper Space Viewport Orientation.
8 REPLIES 8
Message 1 of 9
1220 Views, 8 Replies
I often have the need to change the orientation of my vieports to better fit my project.
I often, and I mean 9/10 times get one or more fata errors when try to do so.
For clarification I am grabbing the wheel in the top right corner between N and E and rotating the view. When I release the drawing is not in view. Then the program crashes.
It is very frustrating and adding hour on to my day.
CPU: (Brand NEW)
MSI GT70
Intel Core i7-3610QM
NVIDIA Geforce GTX 670M/3G GDDR5
12 (+4) GB of RAM
I know I am not running a quadro but I should still be able to handle this type of task.
Please help, no settings or updates I can find solve the problem!
Thank you!!!
8 REPLIES 8
Message 2 of 9
troma
Don't use that wheel!
Try DVIEW TWIST instead.
There's a lot of things that should work, but don't; or work badly.
Mark Green
Working on Civil 3D in Canada
Message 3 of 9
Alfred.NESWADBA
in reply to: troma
Do you mean the viewcube? If so why do you train anyone not to use that, it's great to use it, for 2D view-twisting as well as for 3D isometric views and even for free orbiting; switching between parallel and perspective projection and ....
Or do you have any reason (reproducable) why I'm wrong working with it, loving it and training it?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 4 of 9
Alfred.NESWADBA
That's 90% more than I saw yet, anyway lets start with
  • do you have installed the latest servicepack for Civil3D2012?
  • do you have searched for more current gc-drivers?
  • have you tried to play with hardware-acceleration (command _3DCONFIG ==> Manual Tune)
- alfred -
Alfred NESWADBA
Message 5 of 9
troma
in reply to: Alfred.NESWADBA
- alfred -
OK, so I rarely need to do any of the things you're talking about, so we're approaching this from different angles and workflows. Maybe this is a useful tool for some people, just not for me. But here's my biggest problem:
In a display locked viewport, if you click on the viewcube, it will change your view.
What on earth are they thinking?? What is the point of locking a viewport? Why would you put such a dangerous tool in the drawing space instead of out on a toolbar somewhere, and make it huge (by default) to boot, so it is just too easy to click and drag on it by accident while trying to do something else?
If I want to twist in 2D, I will use DVIEW TWIST so I know exactly what angle I'm twisting. Then I save the view and I can use that view to switch back and forth in model space and also to set up my viewports. Then I lock the viewports.
If I want to rotate in 3D....well it's been so long since I've wanted to that I'd have to think about it. But I know that I don't want to accidentally rotate my view by half a degree off the xy plane and work in my drawing for a couple of hours before I notice! So I've turned off the viewcube and advised the rest of my office to do the same.
A sharp knife in the kitchen drawer is a useful tool. A sharp knife in a child's toybox is just asking for disaster.
Mark Green
Message 6 of 9
Alfred.NESWADBA
in reply to: troma
If I lock my viewport I can't access the viewcube-functions like twisting or orbit or anything changing the display-settings.
So what product (Civil3D?) and what version (+ what servicepack) are you speaking about?
- alfred -
Alfred NESWADBA
Message 7 of 9
troma
I just went and checked, and it still changes the view despite the viewport's being locked.  Although the second time I tried it just locked up & I had to do a 'End Task' to get out, so similar problem to the OP.  I wonder if OP has their viewport locked too.
Where do you find the service pack information in 2011?
Here's a copy/paste from the product information:
[Product Information Properties]
Wednesday 13 June 2012 13:49:20
License name: AutoCAD Civil 3D 2011
Computer host name: SYS154
Product serial number: [DELETED]
License type: Network
License expiration date: None
License behavior: Permanent
License usage type: Commercial
License ID: [DELETED]
License server: [DELETED]
Mark Green
Message 8 of 9
Alfred.NESWADBA
in reply to: troma
tried it now with Civil3D 2011 x64 German, (E 208.N.0 Version 3)
...and it works as designed, if the viewport is locked I can't do twist (or similar) with viewcube.
Start command _ABOUT, you'll get this dialog then, including your current version (incl. servicepack)
- alfred -
Alfred NESWADBA
Message 9 of 9
troma
Thanks!  Used to be in the "Product Information" in 2008...
I have E.116.N.0,AutoCAD Civil 3D 2011 Version 2
Maybe an upgrade would fix this.  Not something I can just do unilaterally though.
Mark Green
Rail Community
