Valued Contributor
tmcmannis
Message 1 of 4 (910 Views)
Fatal Error when changing annotation scale for Viewport
910 Views, 3 Replies
11-26-2012 09:43 AM
Hi everyone. I have some files that are difficult to work with. Every time I try to change the annotation scale of an existing viewport or create a new viewport and set the annotation scale equal to something other than the default 1"=40' the file fatal errors on me. Have any of you encountered this problem, and if so how did you resolve it? Thanks for your help.
Oh, Im on Windows XP 64 (8gb Ram and a Xeon) running C3D 2011 (all service packs and updates applied).
Thanks!
troma
Message 2 of 4 (876 Views)
Re: Fatal Error when changing annotation scale for Viewport
11-27-2012 05:41 AM in reply to: tmcmannis
Some files, not all files?  Sounds like a corruption.
Purge
-Purge   Regaps
Audit
Recover.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
tmcmannis
Message 3 of 4 (869 Views)
11-27-2012 07:23 AM in reply to: troma
It's actually looking like it might be all the files...have yet to find one that we can modify that doesnt crash. We've tried purging regapps, zero length geometry, and everything else and it still crashes.
Just for giggles I ran a Map query to redraw one of the sheets and imported the layout from the original drawing and the problem persists... even with a new from scratch viewport. This is the first time I've encountered this issue and its really proving detrimental to our production speed and output. Please keep the suggestions coming. Thanks for your help!
-Tristan
New Member
gatamunoz10
Message 4 of 4 (625 Views)
09-17-2013 06:43 AM in reply to: tmcmannis
I was able to bypass these errors with the CANNOSCALE command.
Changing the Annotation Scale from the Properties dialog box gave fatal errors. I bypassed this by going inside each viewport and doing the CANNOSCALE then providing the needed scale.
Hope this helps!
