DomagojX
Message 1 of 2 (646 Views)
fatal error: unhandled access violation reading
646 Views, 1 Replies
09-02-2012 08:47 AM
fatal error: unhandled access violation reading 0x0000 exception at f551e6h
this is what i get in civil 3d 2013 64bit running on windows 8 64bit release preview build 8400. I know that it is probably still not fully supported by autodesk but i would appreciate if someone has a solution for this problem.
Civil 3D loads normally. I can load my dwgs without problems. Pan, zoom works. But when i start to do something like drawing, annotating, modifying it takes less than five steps untill i get fatal error message and civil3d crashes.
New Member
uitgeester
Message 2 of 2 (487 Views)
Re: fatal error: unhandled access violation reading
12-10-2012 12:12 PM in reply to: DomagojX
I'm having the same problem! Did you find a solution yet?
