Civil 3D Forum
fatal error - help
7 REPLIES 7
Message 1 of 8
379 Views, 7 Replies
fatal error - help
I am getting  the following fatal error at random times after opening a dwg;  autocad error aborting. Unhandled Access Violation Reading 0x0000 exception 661fd2ech. Any suggestions to fix are appreciated.
7 REPLIES 7
Message 2 of 8
john.mckenzie
Things to try in order that I would try them
run a recover on dwg.
-purge regapps
audit.
-purge general (all)
if that all fails, or this is happening across projects and very randomly.....
Look to see if any add ons can be temporarilly disabled to check stability (if add ons exist)
Repair software
Reinstall software.
Message 3 of 8
 this a new version install. If so, Can your hardware handle the upgrade, If it can, I would start with the install. Something is likely wrong.
Message 4 of 8
Thanks for the advice. I will try your recommendations but I already tried purging and auditing with no luck. This error message and the shutdowns have been occuring since I originally installed the C3d 2013 software on my toshiba laptop. It is 64-bit os running windows 8 with 6gb RAM so I believe it should be able to handle it. Thanks.
Message 5 of 8
wfberry
You originally left out the Windows 8 and C3D 2013.  I think we have found the problem.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014
Message 6 of 8
john.mckenzie
in reply to: wfberry
Bill,
your post indicates that windows 8 and 2013 are incompatible yet the OP says random fatal errors? wouldn't they be continuous fatal error at launch if they are incompatible?
Message 7 of 8
troma
in reply to: john.mckenzie
I remember reading comments on here from quite a few people who tested it out; some on purpose knowing it would have problems, and some with no idea at all. Seems like some things were fine & it would chug along, then other tasks would cause sudden death like this poster.
Mark Green
Working on Civil 3D in Canada
Message 8 of 8
Jeff_M
@john.mckenzie wrote:
Bill,
I found that I could run C3D2013 anywhere from 20 seconds to 10 minutes in Windows8. Installing SP1 AND Hotfix 3 greatly improved stability. SP2 improved the stability even more.
Jeff_M, also a frequent Swamper
Rail Community
