New Member
0 Kudos
Post 1 of 8
fatal error - help
159 Views, 7 Replies
09-04-2013 10:16 PM
I am getting  the following fatal error at random times after opening a dwg;  autocad error aborting. Unhandled Access Violation Reading 0x0000 exception 661fd2ech. Any suggestions to fix are appreciated.
24 Kudos
Post 2 of 8
Re: fatal error - help
09-05-2013 06:52 AM in reply to: sfletch
Things to try in order that I would try them
run a recover on dwg.
-purge regapps
audit.
-purge general (all)
if that all fails, or this is happening across projects and very randomly.....
Look to see if any add ons can be temporarilly disabled to check stability (if add ons exist)
Repair software
Reinstall software.
24 Kudos
Post 3 of 8
09-05-2013 06:54 AM in reply to: john.mckenzie
 this a new version install. If so, Can your hardware handle the upgrade, If it can, I would start with the install. Something is likely wrong.
New Member
0 Kudos
Post 4 of 8
09-05-2013 07:49 AM in reply to: sfletch
Thanks for the advice. I will try your recommendations but I already tried purging and auditing with no luck. This error message and the shutdowns have been occuring since I originally installed the C3d 2013 software on my toshiba laptop. It is 64-bit os running windows 8 with 6gb RAM so I believe it should be able to handle it. Thanks.
161 Kudos
Post 5 of 8
09-06-2013 09:20 AM in reply to: sfletch
You originally left out the Windows 8 and C3D 2013.  I think we have found the problem.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014
24 Kudos
Post 6 of 8
09-06-2013 12:02 PM in reply to: wfberry
Bill,
your post indicates that windows 8 and 2013 are incompatible yet the OP says random fatal errors? wouldn't they be continuous fatal error at launch if they are incompatible?
263 Kudos
Post 7 of 8
09-09-2013 10:52 AM in reply to: john.mckenzie
I remember reading comments on here from quite a few people who tested it out; some on purpose knowing it would have problems, and some with no idea at all. Seems like some things were fine & it would chug along, then other tasks would cause sudden death like this poster.
Credit where credit is due! Give kudos or accept as solution whenever you can.
908 Kudos
Post 8 of 8
09-09-2013 11:03 AM in reply to: john.mckenzie
john.mckenzie wrote:
Bill,
I found that I could run C3D2013 anywhere from 20 seconds to 10 minutes in Windows8. Installing SP1 AND Hotfix 3 greatly improved stability. SP2 improved the stability even more.
