one drawing started receiving the fatal error 0x7ffffffa expection at 6bc7c24dh. Has anyone seen this before? This just started today with only this drawing.
Does this error appear when you are opening the drawing, execute a certain command, or is it just random after being in the drawing for awhile?
A few things that might help would be to do a recover on that drawing. You could also try to copy all the data from that drawing into a clean template to see if that will remove any possible corruption.
