Civil 3D Forum
FATAL ERROR: Cannot write to undo file (probably disk full)
14 REPLIES 14
Message 1 of 15
Kyle-Evans
3800 Views, 14 Replies
Hey guys, I am using Civil 3D 2011, and the last 2 days I have been running into this issue. I tried google, and the most recent item google brought up was from May 2011, so I am coming here.
I am trying to import a tab from another drawing, and it does not matter which tab or what drawing, I am getting this issue.
Does anyone have any ideas?
Thanks!
14 REPLIES 14
Message 2 of 15
Jeff_M
in reply to: Kyle-Evans
Cleaning out your TEMP folder may fix this.
Jeff_M, also a frequent Swamper
Message 3 of 15
fautodesk
This is the only work around I have found for that problem. Save your drawing, type UNDO, enter, type Control (just C), set your undo option to none. Import your tab (or whatever, this may take a while). Save drawing exit Autocad. Make sure your undo is turned back on and continue working.
Message 4 of 15
Kyle-Evans
in reply to: fautodesk
My temp folder is empty, unless there is a hidden one somewhere?
Message 5 of 15
Jeff_M
Make sure Windows Explorer is configured to show System & Hidden files. Then in the address bar enter %TEMP%
Message 6 of 15
Kyle-Evans
in reply to: Jeff_M
Yup, all of my temp files are gone. Where exactly does ACAD put the undo file? I read somewhere that it was limited to 256 MB or so, is this correct?
Message 7 of 15
fautodesk
I would assume it is stored in memeory. I am not positive about that. And I do think you are correct about the size of the undo. I do know that when I get that error message, I set the undo to none, perform whatever operation then just turn the undo back on. I haven't had any other problems doing this.
Message 8 of 15
Kyle-Evans
There is no permanent fix then? I do not want to have to remember to turn undo off and then back on!
Message 9 of 15
AllenJessup
The Undo files should be wherever the Temp dwg location is set in options.
You can also type TEMPPREFIX to check the location.
I believe they are in this format.
Allen
Allen Jessup
CAD Manager - Designer
Message 10 of 15
AllenJessup
BTW If your in Civil 3D your temp folder should not be empty. This could also be caused by a rights issue. If you IT suddenly restricted your rights to the folder I believe that it could cause the message you get. Possibly it would can not write message.
Allen
Well. That didn't make any sense. It is causing a write error.Smiley Surprised
Allen Jessup
Message 11 of 15
Kyle-Evans
in reply to: AllenJessup
All of my temp folders are empty... This is quite annoying now...
Message 12 of 15
cadtech2
It worked Thanks!~
Message 13 of 15
What worked?  I am having the same problem.
Message 14 of 15
cwright
having same problem...
c3d 2013 64 bit.       trying to explode a block.
did "undo, c, n"... same fatal error...
any help appreciated.
Message 15 of 15
cwright
Problem solved.
In case others may have the same problem...
The error, " FATAL ERROR: Cannot write to undo file (probably disk full) was happening when trying to explode a block in a drawing.  The drawing was received from another company, is a trusted dwg and was basically a 'flattening' of a file and all of its reference files.  It was happening in Civil 3D 2013.
The solution is to use Autocad 2013 or Autocad 2014.
The problem also exists in Civil 3D 2014.
Rail Community
