Ok, I've been beating my head against the wall trying to utilize the Data connection tools in Civil 3d 2014. All I ever get is the following error:
Failed to connect.
Failed to open FDO connection.
Couldn't resolve proxy name.
I've read the posts regarding the proxy server and double checked the troubleshooting recommendations Autocad site has to offer. (I already had the all_proxy enviro settings and my server is not a proxy server) Must be something I am missing? I really need to be able to connect to WMS data, specifically through usgs servers. This would extremely expedite the way I perform preliminary work now(download files form National Map Viewer---AIM---then....Civil 3d) If that is what I need to do to get elevation data and orthoimagery, so be it. But.... I know the use of WMS sites would help extremely.
Thanks in any help!
J,
I haven't used WMS, so no clue on what's happening there. But USGS has tons of different ways to grab high-quality images, and just about every state has a site for images. And what about the easiest way ever, Bing Live Maps?
Dave
Dave Stoll
Las Vegas, Nevada
What WMS server are you trying to connect to? Can you post the link here to it?
Try this site
http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?version=1.3.0
Rick Jackson
Survey CAD Technician VI
These are 2 urls I've tried(FEMA link to FIRMS & National Map WMS):
https://hazards.fema.gov/gis/nfhl/services/public/NFHLWMS/MapServer/WMSServer
...but seriously guys, I've tried 20 or so.
I also tried the "run as administrator," check box, and I am running as an admin, still no dice...
Rick Jackson
rl,
Just tried and same error message. Is my firewall blocking access? I check all me settings and everything look normal with med or low security settings?
Got to be something very elementary that I am missing...
jgranberry,
OK, my next questions is what version our you using.
If you are using C3D15 that is part of the Infrastructure Design Suite then you need to download the Map15 Servicepack.
If you are using just C3D15 and do not have the Suite, I believe your out of luck.
Otherwise, I'm unsure of what your issue could be. I use the exact WMS connection I posted on a daily basis to extrapolate flood data into my drawings, verse the insert and scale of the FEMA pdf or image.
Rick Jackson
rl,
I'm running the 2014 Ultimate Design Suite. So all the bells and whistles, as far as your Civil products you would need, but it is all 2014. SO no help there.
And my end goal is to be able to do exactly what you are doing with the software on a day to day basis using the Data Connect utility. For years I've utilized the "drop and scale" method, but I know this is inefficient.
Thanks though...
