Civil 3D Forum
Extrusion direction relative to UCS?
10 REPLIES 10
Message 1 of 11
5871 Views, 10 Replies
I have a polyline, when I list the polyline, the coordinates and elevations are right, but show me "Extrusion direction relative to UCS: X= -0.012 Y= 0.018 Z= 0.958". when I viewed the polylines in Properties, the coordinates are still right, but the Elevations are totally wrong. Could anyone know how to fix the problem? Can I remove "Extrusion direction ..."? I need these polylines to generate a surface in Civil 3D or LDD.
Thanks!
Steven Wang
10 REPLIES 10
Message 2 of 11
ToolPac's Object UCS Fix fill handle this. If this is a one time show,
send me the drawing to dotson at dotsoft.com and I'll fix it.
Terry
The Ultimate Productivity Add-On for AutoCAD
ToolPac 9.0 from http://www.dotsoft.com
Message 3 of 11
Steven hi,
You can try a workaround I used once with points that had the same problem:
Export the geometry to ArcView Shape file and import it back again. It
should be "clean" now.
Arad
wrote in message news:5094548@discussion.autodesk.com...
Thanks!
Steven Wang
Message 4 of 11
hi Arad
Could you please give me more detail instruction about that. I try to export the drawing by using export ArcInfo coverage or *.e00 under map menu in LDD. but I always got the results with 0 elevation. Did i miss something?
thanks
Steven Wang
Message 5 of 11
Hi Steven,
Let me see if I remember correctly.
I had a file with a cloud of points that was not oriented to the WCS.
I created a UCS that was correct relative to the point cloud, and used
WBLOCK to export all the points to a new file.
This solved the orientation problem, but left the points with an extrusion.
The last step was to export all the points to a Shape file (ArcView, 3D).
Importing the Shape back to a clean file got me a fresh set of points that
were oriented correctly and with no extrusion.
Strange problem and a strange solution, but it worked for me. Try it.
Good luck,
Arad
Message 6 of 11
hi Arad
Thanks for your help. I exported the all points to a Shape file (*.shp) and imported it to a new drawing, all the coordinates is correct but the elevations are converted to zero for all points. I don't know how to handle it.
My original problem is I have many breaklines (3dpoly) with various ucs directions. when I list them, the elevation is correct. Now I have to convert them to lines by exploring, then I utilized "drawing cleanup" and chose "delete original objects and creat new objects" to get rid of these extrusion direction. this is not a good way since I can not get the original 3dpoly back automatically.
thanks
Steven Wang
Message 7 of 11
Hi Steven,
I think you might want to check the settings of the EXPORT command.
See the attached picture.
Arad
Message 8 of 11
hi Arad
Finally, I got it. It is wonderful.
Thank you very much for your help.
Steven Wang
Message 9 of 11
Steven,
You are most welcome.
Arad
wrote in message news:5097960@discussion.autodesk.com...
hi Arad
Steven Wang
Message 10 of 11
Try this way.
work on a duplicate file to avoid any missing of datas. once you got the result you can save as with the original name.
1. Explode the polylines.
2. Type "FLATTEN" and enter
3. Now you can join with polyline edit.
I hope this will work.
Message 11 of 11
chris_brenton
I recently was using the LINEWORKSHIRKWRAP on 3dline work and the command would be a LWPolyline that was drawn with extrusion direction relative to UCS.
The flatten command did not work and modified the line work with different x:and y: coordinates.
The solution I found is to use Civil3d's CONVERTPLINES.  Then use CONVERT3DPOLYS.  After doing these two commands, it generated a LWPolyline with a Z elevation that I was able to change back to Zero and removed the "relative to UCS".  This also kept the x and y coordinates the same.
Rail Community
