Hi
When i want to extract polyline from corridor, unexpectedly the program does now give me the chance to choose the right point code.i want to have a polyline from "P1" but it selects "P2" which are on the same vertical line.I am wondering if there is an option to select the point code manually from a list.
I have found a vba (attached) to run it on my civil 3d 2014 but i couldnt.
Can you select the correct one if you go to the corridor properties dialog, feature lines tab and turn off (set style to None or a Hidden Style) the unwanted code?
John Mayo
Yes
