Distinguished Contributor
GreeneSWCD
Message 1 of 4 (158 Views)
Extracting Cross Sections help
158 Views, 3 Replies
11-28-2012 06:05 AM
I have an alignment going up the center of a draw.  I'd like to extract cross sections of this alignment and existing ground.  What is a good way to do this?
I don't do cross sections very often, so when I need one, I draw a second alignment perpendicular to the first and profile that alignment to give me a bare bones cross section.  I'd like to do these cross sections on a given interval, and at every change in direction.  How should I go about it?
Thanks.
Valued Contributor
bo.martin
Message 2 of 4 (155 Views)
Re: Extracting Cross Sections help
11-28-2012 06:19 AM in reply to: GreeneSWCD
My method....
I chose these from the menu bar, So be sure to have it turned on.
Create a profile 1st.
Sections>Create Sample Lines
Sections>Create Section View
Hopefully you have a Style created.
Good Luck,
Bo
troma
Message 3 of 4 (140 Views)
11-28-2012 07:08 AM in reply to: bo.martin
In the create sample lines command there are options to create by station; where you click the location or type the station, or to create by range; where you set the start point, end point and the interval.
Credit where credit is due! Give kudos or accept as solution whenever you can.
GreeneSWCD
Message 4 of 4 (137 Views)
11-28-2012 07:11 AM in reply to: troma
I'm getting there, thanks guys.
