Hi, I have a surface from which I need to extract the outline for set of a specific elevations (e.g. 1.44 m as well as quite a fews others at irregular intervals). I'm familiar with extracting objects such as contours from surfaces, but I'm stuck on how to efficiently create a single contour at a given elevation.
Any suggestions?
- Mick
Solved by Jeff_M. Go to Solution.
Well I'm learning every day !
I had briefly looked at that but missed the display user contours bit as you noted at the bottom of your post - I never actually noticed that this was separate from the other contour categories.
Thanks Jeff ! Perfect solution
- Mick
