So simple little retaining wall subassembly created in the SAC. When i extract multiple feature lines from a corridor using this subassembly, all the feature lines assume the elevation of the first link i selected. So if i first click on 'RW_Hinge" all successive feature lines will show up with the same elevations as "RW_Hinge". if i erase all the feature lines the select a different link say "RW_Top" then they all go to "RW_Top". any thoughts?
Solved by conormccartney3897. Go to Solution.
I get tihs error when I attempt to import it.
Did you perchance use a "newer" subassembly composer?
Strange. i get that error both in 2011 and 2012. Sorry, I can't help. I'm not sure what the problem is. Maybe I'll try re-installing the Composer.
So I tried your subassembly in a "different" version of Civil 3D and it works. This corresponds with the error I get. Do you have that "different" C3D version installed?
So I used this different version and I don't get the same problem as you. Can you attach a DWG file and point out exactly what you're trying and what youre seeing as being a problem?
Matthew: im using C3D 2011 verstion E.208.N.0, Version 3, i attached the test drawing i was using.
Mark: hrmm i think your right i seems to be working fine when i extract from opposite sides of the corridor, although it wasnt previously. but yes my links are truly vertical. although it displays a little wierd when you look at teh corridor in isometric view, the links are not matching the points. /forehead slap problem solved is suppose.
Well, you've got unique point codes for each point in the wall, so you should get unique feature lines from that. I would suggest offsetting your top just slightly - something like 0.05 from the bottom (with the bottom being wider).
I can say, when something is off in a subassembly, the errors I get don't necessarily make sense all of the time - like"oh, I missed a code or something"... often times the errors are "what they hell?"
I tried to find a way to define a wall feature line in my subassembly and couldn't figure it out... nobody will notice a 0.05 offset except you and it might alleviate the issue with little work...
I don't have any other suggestions...
good luck - let me know how it all figures out...
you can see my 0.1' contours run up my wall well with my 0.05 offset at the top... FWIW...
Mark.
