Civil 3D Forum
Extract volumes from a surface between to specific elevations?
3 REPLIES 3
Lieblaw
382 Views, 3 Replies
How can I extract volumes from a surface between two specific elevations?  So if my range of elevations varies from 400' to 2500', how can i extract the volume from 1000' up to 2500' without any of the other volumetric data from the surface areas bleow the 1000'?  Is that even possible without creating a profile?  I am using Civil 3d 2014.  Any help will be greatly appreciated!
-Ryan
3 REPLIES 3
neilyj666
in reply to: Lieblaw
Create a surface at 1000' and do a TIN volume surface between this and the other surface or just a simple analysis between the two surfaces.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Lieblaw
in reply to: neilyj666
The range of elevations on the surface I'm trying to extrapolate the volume from is existing. Are you suggesting there is a method to only create a surface from a designated elevation on the existing elevation or to create that surface from the contours?
Joe-Bouza
You cant get a volume from a single surface you must compare one surface to another
Joe Bouza
Rail Community
