mheimburger
Message 1 of 3 (288 Views)
Extract Survey Data from Vault
288 Views, 2 Replies
09-17-2010 10:23 AM
When we changed from LDD to C3D we installed Vault and completed several survey projects.  Now we are moving away from Vault and would like to move the survey data.  I go through the process of converting from Vault to Data Shortcuts but the survey data is not available.  Files Survey.sdb & Survey.sdx are tranferred but when I direct the working folder to their location no survey database shows up.  Is there a way to utilize the survey data without using Vault?
What you can do is go to Vault Explorer and check out Survey.SDB file. This will make a copy of the survey database in your Working Folder directory. Then see if you can obtain your survey database.
Check this link for reference: http://beingcivil.typepad.com/my_weblog/2010/05/from-vault-to-data-shortcuts-move-survey-database.html
Let me know if it helps.
Product Support
AlmasSuljevic
Message 2 of 3 (277 Views)
Re: Extract Survey Data from Vault
09-17-2010 01:42 PM in reply to: mheimburger
Check this link for reference: http://beingcivil.typepad.com/my_weblog/2010/05/from-vault-to-data-shortcuts-move-survey-database.ht...
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
mheimburger
Message 3 of 3 (251 Views)
09-21-2010 10:34 AM in reply to: AlmasSuljevic
Thanks Almas, you had sent me that link previously and I lost it.  It works great.
