Hi there
Does anyone know of a way to extract lines from an Xref'ed corridor into the current drawing?
Solved by Jeff_M. Go to Solution.
Joe Bouza
Christopher Fugitt has a free tool to do this.
http://style.civil3dreminders.com/civil3dreminderspack
John Mayo
Interesting tools, but I seem to have a problem loading them in 2015. Here's what my command line looks like:
Command: NETLOAD Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Users\mkt\Dropbox\Jobb\Materiale\C3DRemindersPackFree\C3DRemindersPackFree.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515) File name: 'file:///C:\Users\mkt\Dropbox\Jobb\Materiale\C3DRemindersPackFree\C3DRemindersPackFree.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information. at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark) at System.Reflection.Assembly.LoadFrom(String assemblyFile) at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName) at loadmgd()
The C3DRemindersPack was built for C3D2011 and will not work in C3D2015. Although the error you see there probably stems from the downloaded zip file being 'blocked' by Windows. You must Unblock it in the file's Properties before extracting the contents. That being said, this command, and others, have been added to the Sincpac-C3D package of tools.
