Civil 3D Forum
Extract Corridor Solids does not work for Surface Links
12 REPLIES 12
Message 1 of 13
ceethreedee.com
1957 Views, 12 Replies
Can anyone confirm if the extract corridor solids works when your shape follows the surface with a surface link. 2014 definately doesnt work. Does 2015.
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
12 REPLIES 12
Message 2 of 13
lim.wendy
in reply to: ceethreedee.com
Hi Kapanther,
Below is the result I get:
Smiley Wink
____________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 3 of 13
ceethreedee.com
in reply to: lim.wendy
Oh yeah!
Time to switch!
giggity... gig ... gig gig . potatoes!
Smiley Happy
Infraworks 2021.1,
ceethreedee.com
Message 4 of 13
ceethreedee.com
Well... hopefully it is just something I am doing wrong. Does Extract corridor solids work for custom subassemblies? It seems to only export the link codes?
I tried on a smaller section of my corridor.. it just creates a blank file?
Infraworks 2021.1,
ceethreedee.com
Message 5 of 13
lim.wendy
Unfortunately, the ability to create a corridor solid from a custom subassembly does not work. Smiley Sad
This has already been escalated to the development team.
Apologies for the inconvenience.
Wendy Lim
Customer Value Hub
Message 6 of 13
ceethreedee.com
If only I could take back my kudos..... Smiley Tongue
I really hope this gets fixed soon!
Infraworks 2021.1,
ceethreedee.com
Message 7 of 13
Cadguru42
Has this been fixed, yet?
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 8 of 13
neilyj666
Doubt it
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 13
Are there any news? Has the problem been solved?
Message 10 of 13
I have the same problem. I have created a corridor from bespoke subassembly, in which I used Surface Link, and when I hit the button "Extract Corridor Solids" nothing happens 😞 Is there any way around it?? The corridor itself looks fine.
I'm using Civil 3D 2016.
Message 11 of 13
S_D_W
in reply to: black.mamba535
Same problem here!
Maybe you could try to place multiple points on surface with a spacing of x meters and connect these points with a link. So you create a shape consisting of just points and links. Didn't try it myself yet.
Kind regards,
Joost
Message 12 of 13
S_D_W
In my previous reply I talked about adding multiple points with delta X on surface and connecting these points with a link. It is a time consuming process adding all these points (depends on the interval and total number of points) but it is an easy workaround and works for me!
Hopefully this works for you too!
Message 13 of 13
sb208918
in reply to: S_D_W
It kind of works now. But the solids are not pretty.
Check this out:
https://forums.autodesk.com/t5/civil-3d-forum/corridor-extract-solid-issue/m-p/8913783#M403374
Rail Community
