Have you tried specifying a minimum/maximum elevation within the surface
properties?
(I do not think you can filter the point data from an external file....I
could be mistaken, though.)
wrote in message news:5522845@discussion.autodesk.com...
If I use point utilities / transfer to convert an ASCII file for an external
point database file to build a surface, how can I filter out bad elevations?
For example, normally we create point groups and tell them to exclude
certain elevations, point descriptions with no elevation, etc... Does this
have to be done before I use the points transfer tool? I am using Civil 3D
2006 with Windows XP, any insight would be greatly appreciated, thanks.
Lang
