neilyj
Message 1 of 11 (269 Views)
Extent of rockfall netting
269 Views, 10 Replies
11-13-2012 12:08 PM
I have a model of a platform at 29.00m cut into rock and need to find  areas where the rock cut is 2m or more as this will require netting - any ideas of a quick way to do this??
 Extract the 31m contour and see where it runs is the best I've come up with......
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Neilw
Message 2 of 11 (266 Views)
Re: Extent of rockfall netting
11-13-2012 12:36 PM in reply to: neilyj
Would not a CUT/FILL depth analysis work?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
neilyj
Message 3 of 11 (261 Views)
11-13-2012 12:45 PM in reply to: Neilw
The excavation surface vs a 31m plane surface??
neilyj
Neilw
Message 4 of 11 (258 Views)
11-13-2012 12:48 PM in reply to: neilyj
I don't understand your scenario. I assumed you have a proposed surface and want to determine where the cuts are >2m vs. the existing. What do you have to work with?
WIN 7 64 PRO
RADEON 6450, 1 GB
neilyj
Message 5 of 11 (254 Views)
11-13-2012 01:04 PM in reply to: Neilw
Yes I have a proposed surface and I'm only really interested in the portion that is below rockhead and is higher than 2m above the platform level
neilyj
Neilw
Message 6 of 11 (247 Views)
11-13-2012 01:30 PM in reply to: neilyj
In the ranges for the depth analysis, only include those values that fall within the desired parameters.
WIN 7 64 PRO
RADEON 6450, 1 GB
BrianHailey
Message 7 of 11 (230 Views)
11-13-2012 03:50 PM in reply to: neilyj
No. Create a volume surface of your platform and your rock surface. Run an elevation analysis on the volume surface. Anywhere the elevation of the volume surface is greater than 2m is where you will need the protection. You can then stylize the volume surface and to display those areas automatically if the design changes.
Brian Hailey
CAD-1.com
My Blog
Neilw
Message 8 of 11 (226 Views)
11-13-2012 04:11 PM in reply to: Neilw
I assumed you knew how to create a cut/fill analysis. My apology for not being more explicit.
WIN 7 64 PRO
RADEON 6450, 1 GB
neilyj
Message 9 of 11 (206 Views)
11-14-2012 12:25 AM in reply to: BrianHailey
Thanks Brian I'll try that ....
This will identify the locations where the rock netting is required but the next task is to compute the area of the rock face to be netted.
Perhaps draw a boundary around the affected areas, apply as outer boundary and review the 3D area surface properties??
neilyj
Valued Contributor
witzel
Message 10 of 11 (190 Views)
11-14-2012 05:59 AM in reply to: neilyj
I just checked and I believe in the Legend table for volumes you can add 3d area or 2d area.  We use it all the time in the slopes legends to calculate sq footage of walls.
Hope that helps,
Conan Witzel
