That such a nice day to all , I have the following query , some time ago I showed how I could handle dwg files with topographic contours of large areas and in a matter of file size were very large, in the example I showed associating topographic curves file using the "Task Panel" plain 3D , the file was asiciado the project but not carried as such topographical curves , however could use them to define and generate surfaces , something like the "Data Shortcuts " when performing any change in the topography in automatic file was updated in my project where I had referenced as an external reference . I have tried to do this but I can not get the result , because if I can associate the file with the Task Panel topograifia and achievement curves displayed in my project but I can not use them to define my area that I intend to create . Ojala and could guide me because by this method , extensive surveying projects become more practical to use and not Encourage the use of my pc .
Greetings !
Amigo,
you'd better write directly in portuguese, 'cause your Google Translate version is not quite understandable...
Obrigado, y viva el fado !
they do not use the google translator but then you put it in Spanish also hope and so if you can understand and if you can colaborarme i will be grateful.
Greetings and thanks
Traduccion 1:
Que tal buen dia a todos, tengo la siguiente consulta, hace algun tiempo me mostraron como podia manejar archivos dwg con curvas de nivel topograficas de areas extensas y que en cuestion de tamaño de archivo eran muy grandes, en el ejemplo que me mostraron asociaban el archivo de curvas topograficas mediante el "Task Panel" de civil 3D, el archivo quedaba asiciado al proyecto pero no cargaba como tal las curvas topograficas, sin embargo podia utilizarlas para definir y generar superficies, algo asi como los "Data Shortcuts", cuando realizaba algun cambio en el archivo de topografia en automatico se actualizaba en mi proyecto donde lo tenia referenciado como una referencia externa. He tratado de realizar esto pero no logro conseguir el resultado, ya que si puedo asociar el archivo de topograifia con el Task Panel y logro visualizar las curvas en mi proyecto pero no puedo utilizarlas para definir mi superficie que pretendo crear. Ojala y me pudieran orientar ya que mediante este metodo, proyectos de topografia extensa se vuelven mas practicos de utilizar y no alentan el uso de mi pc.
Saludos!
Traduccion 2:
pues no utilice el traductor de google pero entonces te lo pongo en español tambien espero y asi si lo puedas comprender y si puedes colaborarme te estare agradecido.
Saludos y gracias
Hermano,
no puede comprender su "spanglish", lo siento.
Gentlemen Expert Elites,
if some of you lives in New Mexico, would you please decode what Daniel is asking about, in order to help him?
Gracias, hombres!
Mark Green
Working on Civil 3D in Canada
ok bueno haber si asi se comprende mejor:
Saludos!
Daniel,
if your native language is Portuguese, you can try to ask for help at AutoCAD Civil 3D - Português forum...
(se a tua lingua materna é o Portugês, podes tentar pedir ajuda no forum do AutoCAD Civil 3D - Português)
HTH
(espero que ajude)
Henrique
I'd love to have an Italian one, Henrique: how might I get it..?
Antonio,
just trying to help, there were "some" translation difficulties from the OP...
Never understood why don't exists an Italian forum...
But I promise, if I find it, I'll post the link...
EDIT: and I'm not sure what the OP is Portuguese!
Henrique
Mark Green
Hola troma, gracias hasta que alguien si entendio lo que preguntaba, que tan dificil era leer y eneteder pero bueno, mira estoy utilizando la version 2014, y si puedo generar superficies ya sea TIN o Grid y definirlo con polilineas, lineas, puntos, 2d polilineas siempre y cuando tenga estos elementos en el archivo de mi proyecto, el detalle es que tengo archivos muy grandes de topografia y creo que puedo generar superficies asociando los archivos topograficos sin la necesidad de insertar los elementos para definirlo. Esto no hacerlo necesariamente con los Data Shortcuts por que en este metodo tendria que ocupar primero el archivo base de topografia, generar la superficien y entonces ahora si crear un Data Shortcuts de superficie para asociarla a otro proyecto.
Mark Green
