hi
please i have qusent about alignment labels
i want to creat expression (offset*0.02+profile level) or (offset*superelevation slope+profile level)
offset from center line
0.02 is the section slope or if i can use the superelevation slope for alignment for i can solve the transition slope area
so can i do that expression in alignment geometry label
thank u
The problem here is that you're trying to calculate using parameters which are normally part of different label types. Profile elevations can be displayed in alignment station/offset labels but they cannot be used in expressions. The better way to do this is to create a corridor model for the road you're trying to design and label that directly.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
