AutoCAD Civil 3D General Discussion
*Expert Elite*
Sinc
Message 1 of 3 (124 Views)
Expression Bug
124 Views, 2 Replies
02-28-2009 07:47 AM
Anyone ever noticed this?
Assume we have a point with elevation 1234.56.
Using this expression:
{Point Elevation}-(TRUNC({Point Elevation}/100)*100)
returns a result of 34.56.
But using *this* mathematically-identical expression:
{Point Elevation}-(100*TRUNC({Point Elevation}/100))
returns a value of 1134.56.
(Tested in C3D 2008 & 2009.)
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
*Jeff Mishler
Message 2 of 3 (124 Views)
Re: Expression Bug
02-28-2009 09:06 AM in reply to: Sinc
Yes, I've seen this before with other expressions. It seems like the
Expression evaluator expects things in a certain order, mix that order up and
just the first item is evaluated.
Attached is a pic showing the results that you've discovered.
Whenever I create an expression now, I make sure to double & triple
check the results before accepting it for use.
Anyone
ever noticed this? Assume we have a point with elevation 1234.56. Using this
expression: {Point Elevation}-(TRUNC({Point Elevation}/100)*100) returns a
result of 34.56. But using *this* mathematically-identical expression: {Point
Elevation}-(100*TRUNC({Point Elevation}/100)) returns a value of 1134.56.
(Tested in C3D 2008 & 2009.) -- Sinc http://www.ejsurveying.com
Employee
Matt.Anderson
Message 3 of 3 (124 Views)
Re: Expression Bug
03-01-2009 08:05 PM in reply to: Sinc
Yes, expressions have returned odd results based on the order of operation. I haven't checked if that got fixed in v3.1 (sp2.1)
Matthew Anderson, PE
Product Manager
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
