Civil 3D Forum
Expression Bug
2 REPLIES 2
Sinc
207 Views, 2 Replies
Expression Bug
Anyone ever noticed this?
Assume we have a point with elevation 1234.56.
Using this expression:
{Point Elevation}-(TRUNC({Point Elevation}/100)*100)
returns a result of 34.56.
But using *this* mathematically-identical expression:
{Point Elevation}-(100*TRUNC({Point Elevation}/100))
returns a value of 1134.56.
(Tested in C3D 2008 & 2009.)
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
2 REPLIES 2
in reply to: Sinc
Yes, I've seen this before with other expressions. It seems like the
Expression evaluator expects things in a certain order, mix that order up and
just the first item is evaluated.
Attached is a pic showing the results that you've discovered.
Whenever I create an expression now, I make sure to double & triple
check the results before accepting it for use.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Anyone
ever noticed this? Assume we have a point with elevation 1234.56. Using this
expression: {Point Elevation}-(TRUNC({Point Elevation}/100)*100) returns a
result of 34.56. But using *this* mathematically-identical expression: {Point
Elevation}-(100*TRUNC({Point Elevation}/100)) returns a value of 1134.56.
(Tested in C3D 2008 & 2009.) -- Sinc http://www.ejsurveying.com
Matt.Anderson
in reply to: Sinc
Yes, expressions have returned odd results based on the order of operation. I haven't checked if that got fixed in v3.1 (sp2.1)
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Rail Community
