Active Contributor
3 Kudos
Post 1 of 13
exporting to terramodel
758 Views, 12 Replies
12-10-2012 07:38 AM
hi.  we have a surveyor who uses terramodel.   with 2010 we used to be able to export to a 2000 dwg and he could then convert and import to a .pro file.  now, with 2013, when we do the same thing, he gets errors.  we need to figure out a way to get our info into his program.
thanks,
-wes
343 Kudos
Post 2 of 13
Re: exporting to terramodel
12-10-2012 08:52 AM in reply to: boyerengineering
What are you trying to export??
Is LandXML an option??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
3 Kudos
Post 3 of 13
12-10-2012 09:00 AM in reply to: neilyj
we need to get him the linework, blocks, etc, as well as layers, points, and hopefully the surfaces.  we do not have landxml.  would be willing to get it, but id prefer to keep everything simple and not have a ton of conversion software on the computers.
267 Kudos
Post 4 of 13
12-10-2012 09:04 AM in reply to: boyerengineering
LandXML is built into most civil design packages (there is an export to LandXML command in C3D). This allows you to export civil design information from one design package to another (kind of like we had to do with .dxf back in the days when AutoCAD couldn't read a .dgn and Microstation couldn't read a .dwg).
If you are looking for just linework, go to your application menu and export to a 2010 AutoCAD drawing:
http://screencast.com/t/92IRgkkzRg0f
Brian Hailey
CAD-1.com
My Blog
Active Contributor
3 Kudos
Post 5 of 13
12-10-2012 10:45 AM in reply to: BrianHailey
ive exported it into 2010, 2007, you name it.  he cant open/convert it.  ill look into landxml.
thanks.
267 Kudos
Post 6 of 13
12-10-2012 12:28 PM in reply to: boyerengineering
LandXML won't take drawing objects, just design data. Are you exporting or saving to a prior version? There is a HUGE difference.
Brian Hailey
CAD-1.com
My Blog
343 Kudos
Post 7 of 13
12-10-2012 01:16 PM in reply to: boyerengineering
the surfaces will xmlout with no problem but as Brian says make sure you are exporting rather than saving as...
neilyj
Valued Contributor
9 Kudos
Post 8 of 13
12-10-2012 01:19 PM in reply to: boyerengineering
In Terramodel every layer is a DTM by default. If you need to export a surface, put all the elements (breaklines, points) that define that surface into ONE layer. Then it will form up properly in Terramodel.
Also try not to export files with  2D polylines. For example if you create a polyline from a line that has different start and end elevations, you will create a polyline that sits in its own rotated coord system, and Terramodel does not import these properly.
Terramodel will read 2007 DWG files without a problem, so doing a 2007 AutoCAD export should work fine.
Hans Moller
Surveying & Management Services
Gladstone Australia
Clevo Metabox 16GB, Intel i7-3720QM 3.1Ghz, 256GB SSD, Nvidia GTX 680M
AutoCAD Civil 3D 2013
Active Contributor
3 Kudos
Post 9 of 13
12-10-2012 01:37 PM in reply to: BrianHailey
i exported it to a 2007 dwg and saved it to a 2007 dwg.  neither worked, but which should i be doing?  id like to focus on just getting him the linework for now.  he can recreate a surface from the contours.
thanks all.
267 Kudos
Post 10 of 13
12-10-2012 01:40 PM in reply to: boyerengineering
If you "Save As" you will be saving a Civil 3D drawing. You can then reopen that drawing in whatever version of Civil 3D you created it with and continue to work. If you "Export" you are converting all that Civil 3D stuff to AutoCAD entities and you lose all C3D data.
Brian Hailey
CAD-1.com
My Blog
