with regards to exporting the tadpoles, the process that i used to know is by exploding the corridor twice to be able to get the tadpoles, or by exporting first to AutoCad from Civil 3d then copying the tadpoles. The problem is when the file is too big, it takes a lot of time doing either of the two process. do you have any other process that i could do to lessen the time of exporting? is there any way that i can export the tadpoles as genio?
thanks.
neilyj (No connection with Autodesk other than using the products in the real world)
