Whether I export an rxl through the Trimble Link or an xml file, then use TBC to create the rxl file; my alignment is not exporting 3D (with a profile).
What I am wondering is if anybody knows a way to export a surface profile (or even a profile by file) so that the alignment is 3D. I know that it works fine providing it is not a surface profile format.
Currently if I create a surface profile, or create a profile from an imported text file, I have to export the alignment and profile into a xml file. I then take that file and manually change the station & elevation format to fit the <PVI>0.000 20.65</PVI> format.
If anybody knows of a way to change the format or convert a surface profile into just PVIs, I would be glade to hear.
Below is the format that I can not export my alignments into a 3D rxl file, only a xml file that AutoCAD can read. TBC can not recognize this format.
<Profile name="FOC_North-East">
<ProfSurf name="FOC_North-East (OG-Topo)" state="existing">
<PntList2D>-0.000000000492 29.947 0.26498725113 30.028178690208 0.356266782372 30.035765173806 0.407086985509 30.023447820398 0.428273793094 30.026791947024 0.738021748822 30.078634619658 1.047769704551 30.132600158837 1.35751766028 30.187064412566 1.411026195477 30.196276027291 1.533420490293 30.266974063655 1.63877376583 30.232589426021 1.667265616008 30.235330858184 1.977013571737 30.268303579963 2.286761527466 30.303453313628 2.596509483194 30.339722189719 2.932507064311 30.379278253961 4.590383908962 30.488237457602 4.625205668019 30.490626310616 6.600577025761 30.612 9.032288473227 30.719507428584 9.847792903692</PntList2D>
</ProfSurf>
Below is the xml format that I am need to export 3D rxl files.
<ProfAlign name="BFOC-Topo (1)">
<PVI>-0.000000000931 29.946999999974</PVI>
<PVI>0.26323583629 29.996999999974</PVI>
<PVI>1.115932909772 30.140000000037</PVI>
<PVI>1.538792792708 30.220000000019</PVI>
<PVI>2.921552265063 30.378000000026</PVI>
</ProfAlign>
</Profile>
</Alignment>
