I have a boudary of several parcels I'm trying to export to and ARC Shape file. I selected the layer they resided on and Layer 0, but the Parcels dont seem to be exporting.
Is it my parcels dont export? Or am I doing something wrong
Rick Jackson
Survey CAD Technician VI
You can _MAPEXPORT only the following kinds of objects:
so you should first convert your parcels to those elementary stuff, sir.
Use ExportToSDF command to export the parcels to an Autodesk Spatial Data Format file. Start a new drawing and MapImport the SDF file you created.
Use MapExport to then export the imported polylines to SHP.
Be sure you export data fields with the SDF, create object data during MapImport and export Object Data with the MapExport to SHP.
