Civil 3D Forum
Exporting North Arrow
2 REPLIES 2
ChrisGIS
375 Views, 2 Replies
I have a North Arrow symbol in AutoCAD and I'm trying to export it to a shapefile, .jpg or any kind of format that I can use in ArcMap.  I'm new to AutoCAD please be specific as possible.  Thanks in advance.
2 REPLIES 2
ToddRogers-WPM
in reply to: ChrisGIS
Type MAPEXPORT and export it out as an ESRI shapefile.
Todd Rogers
Murph_Map
in reply to: ToddRogers-WPM
Exporting it to shp format will work however, if the north arrow in in PS then the inserting point may not be what you want and if there is a coordinate system assigned to the dwg that may aso cause an issue in ArcGIS on moving it and placing it where it needs to be.
I would suggect using jpg format.
Type jpgout and select the north arrow, or if there is a lot of detail in the symbo; than setting up a raster plotter from the plotter wizard and select raster format.
Murph
Supporting the troops daily.
Rail Community
