Civil 3D Forum
exporting LAT LONG off state plane DWG file
4 REPLIES 4
hislopcd
3384 Views, 4 Replies
                I am extremely new to using CIVIL, my goal is to export a bunch of points placed on a DWG that was done with state plane coordinates.  I used to be able to do this in CIVIL version 2012 by using the MAPEXPORT command, I have done enough research to find the DATAEXTRACTION command in CIVIL 2013, so I have the process of exporting down, but I cannot figure out how to get the points to read in LAT-LONG instead of state plane coordinates…  any hints would be MUCH appreciated.
Thank you!
4 REPLIES 4
antoniovinci
in reply to: hislopcd
In the Options tab of the MAPEXPORT command, check "Convert coordinates to" and ensure you have LL83 (or LL84) in that field, sir.
hislopcd
in reply to: antoniovinci
Thank you very much for the reply, MAPEXPORT was the command I had been using before we had upgraded to 2013.  It used to export my points nicely to a DBF file, but now it wants the information to go to a SDF file, which I seem to not be able to open.  That is when I found out about the DATAEXTRACTION command.
wfberry
Keeping it in the Civil 3D arena, it is quite easy to make a Lat Long point label.
Bill
hislopcd
in reply to: wfberry
how does one do that? and export many of them to a file that excel can read??
Rail Community
