Valued Contributor
johnwilson0805
Message 1 of 10 (1,898 Views)
Exporting data to HEC-RAS Format
1898 Views, 9 Replies
12-01-2012 03:55 PM
I created a surface and a stream centerline alignment and ran cross sections to prepare to export to HEC-RAS.
I go to Output tab / Export panel / Export to HEC_RAS / and in the table It shows my surface (EG2) and
Site but when I click the alignment down arrow and it shows only "NONE". I selected the greem box to pick my
alignment and it apeared to pick it but it does'nt show my alignment called "CL CREEK"  in the dialog box.
And it is similar to my cross section options. I went ahead and tried to export it but my GEO file has zero bytes
Thanks John Wilson
Did you try playing with the Site dropdown. The Alignment may have been put in a Site that you didn't expect?
Neilw
Message 2 of 10 (1,889 Views)
Re: Exporting data to HEC-RAS Format
12-01-2012 05:29 PM in reply to: johnwilson0805
I suggest you search the news group on the topic. There are several posts about problems with this tool. I personally decided not to invest time trying to work through the problems.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Mentor
fcernst
Message 3 of 10 (1,880 Views)
12-02-2012 06:32 AM in reply to: johnwilson0805
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Valued Contributor
johnwilson0805
Message 4 of 10 (1,861 Views)
12-02-2012 09:16 AM in reply to: fcernst
Thanks Fred for responding
My drawing has several sites. I went thru some of them but I'll go thru all.
Thanks again
John
Valued Mentor
fcernst
Message 5 of 10 (1,859 Views)
12-02-2012 10:23 AM in reply to: johnwilson0805
Yes, make sure you look under <None> also there.
Many times Alignments are not placed under any Sites, so they don't interact with other objects.
Fred Ernst, PE
C3D 2015
Ernst Engineering
New Member
2ndLt
Message 6 of 10 (1,742 Views)
02-22-2013 01:02 PM in reply to: fcernst
Anybody knows how can I export a designed work (let's say a designed surface) for Hec-RAS (.geo format) Is it possible to do it or not, and if it is what are the steps?
I know how to export an EG to hec-ras!
BrianHailey
Message 7 of 10 (1,718 Views)
02-24-2013 01:48 PM in reply to: 2ndLt
There's no difference between an EG surface and a Design surface in the eyes of Civil 3D. Just export the design the same way you would export the EG.
Brian Hailey
CAD-1.com
My Blog
New Member
2ndLt
Message 8 of 10 (1,681 Views)
03-01-2013 02:32 PM in reply to: johnwilson0805
OK, that's easy, but doesen't work. I mean, it doesent work to me, maybe I do some mistakes, I don't know. Tell me how you do it! Do you make form a coridor a new surface and then you export it to hec-ras or what?
Thank you for response
New Member
yashodhan19
Message 9 of 10 (920 Views)
Export to HEC RAS
01-12-2014 05:38 AM in reply to: johnwilson0805
I am facing a problem while exporting CIvil 3d data to HEC RAS. First i created a surface by using the Google Earthextension. I defined the alignment. I defined the section lines. Under Export to HEC RAS tab i selected the surface, alignment & section line group. Initially after creating the .gro file and later importing it to HEC RAS i could clearly see the data as in the Civil 3d viewport. Now when i try to import HEC RAS shows an error saying that some of the sections are beyond reach extends. it also offers to remove georeferncing but if i do that the alignment is just a straight line with the cross sections. Moreover the direction is also flipped.
Also i wish to know how can one import an entire river network to HEC RAS.
New Member
estelarubin64
Message 10 of 10 (579 Views)
05-27-2014 06:34 PM in reply to: 2ndLt
I am working on the finished surface created from the corridor.  When I tried to export to HEC-Ras, it doesn't have any points in it.  How can I do this?  I already made another sample lines just for the finished surface, still it didn't work?  I hope smebody can reply on query.
