New Member
0 Kudos
Post 1 of 6
Exporting curved feature lines and retaining the elevations
582 Views, 5 Replies
01-03-2013 09:25 AM
I have a series of curved feature lines in Civil 3D where the elevation varies along the length of the curve. When I export the file in AutoCAD the feature line elevations are 0. In my previous version of 2010 civil 3D this did not happen but now I am running 2012 version and I can't find a way around it.
Why does 2012 Civil 3D not export feature lines the way it did in previous versions and retain the elevations?
How can i overcome the issue?
Tracey
I can't say I remember that about 2010, but if you switch to a 3D view BEFORE you do the Export, the linework will have proper elevations.
288 Kudos
Post 2 of 6
Re: Exporting curved feature lines and retaining the elevations
01-03-2013 10:30 AM in reply to: tracey.boyle
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Mentor
36 Kudos
Post 3 of 6
01-03-2013 11:44 AM in reply to: mathewk
I find the same problem, Matt. Exporting to autocad, the feature lines are supposed to convert to 3d or LW plines with elevations depending on what the FL was.
I get 0 elevations out.
It used to work and is "supposed" to work. A bug?
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
419 Kudos
Post 4 of 6
01-03-2013 01:29 PM in reply to: ericcollins6932
I reported this to Autodesk Support a while back.  The story I got is that this behaviour is what the programmers originally intended.  If you export a drawing from a 2d viewpoint then you get 2d objects at zero elevation, or if you export from a 3d viewpoint then you get 3d objects.  Unfortunately they could not make the feature work correctly, so they disabled it, and left it defaulted to 3d export all the time.
Recently the underlying issue with featurelines was resolved, as part of the fix that allows us to have featurelines which display linetypes correctly.  Once that happened somebody turned the switch for the export option back on, but they didn't tell anyone else.
Active Member
0 Kudos
Post 5 of 6
12-05-2013 06:10 AM in reply to: tracey.boyle
When I export in WORLD ucs the feature lines after export have a 0 elevation...
We need the feature line elevation in plan and not in 3d visualization, this bug happens after civil 3d 2012...
Somebody could help me?
Ienlov
267 Kudos
Post 6 of 6
12-05-2013 06:33 AM in reply to: Ienlov
Did you try the solution above?
You can always switch it back to a 2d plan view & World UCS after you do the export.
Credit where credit is due! Give kudos or accept as solution whenever you can.
