Civil 3D Forum
EXPORTING CROSS SECTION LABEL
2 REPLIES 2
ARAOYEC3D
560 Views, 2 Replies
HOW CAN I EXPORT THE DATA IN THIS CROSS SECTION TO EXCEL SHEET...HAVE BEEN DOING IT MANUALLY WHICH IS TIME WASTING.  LOOKING FORWARD TO HELP IDEAS. I WILL LIKE TO EXPORT THE CHAINAGE NO, THE OFFSET, THE EXISITING LEVEL AND PROPOSED LEVEL DATA TO EXCEL SHEET.cross section data.jpg
2 REPLIES 2
LASSAADTH
in reply to: ARAOYEC3D
You can use the command _dataextraction and select the items to retrieve.
Good luck.
Lassaad THALJAOUI
Infrastructure Engineer
Autodesk Product professional User
Civil 3D 2016 x64 / Windows 7 64-bit / 16GB RAM
david.zavislan
You could also generate that data from the corridor reporting tools.  The Slope Stake Report or Section Points Report may give you the data that you need.  Set the report file type to xls to make it easy to cut and paste to your spreadsheet.
David Zavislan, P.E. | Wood Rodgers, Inc.
Rail Community
