HOW CAN I EXPORT THE DATA IN THIS CROSS SECTION TO EXCEL SHEET...HAVE BEEN DOING IT MANUALLY WHICH IS TIME WASTING. LOOKING FORWARD TO HELP IDEAS. I WILL LIKE TO EXPORT THE CHAINAGE NO, THE OFFSET, THE EXISITING LEVEL AND PROPOSED LEVEL DATA TO EXCEL SHEET.
Solved by david.zavislan. Go to Solution.
You can use the command _dataextraction and select the items to retrieve.
Good luck.
You could also generate that data from the corridor reporting tools. The Slope Stake Report or Section Points Report may give you the data that you need. Set the report file type to xls to make it easy to cut and paste to your spreadsheet.
