Member
THEBOLT
Message 1 of 3 (142 Views)
exporting contours from autocad civil 3d to autocad
142 Views, 2 Replies
04-10-2014 10:14 PM
hey,
i want to export civil 3d contours to autocad but flattening the contours and still defining the elevations of of the contour. is this possible ?
thankyou
You can export the contours with elevations, or flattened to zero.  What you export depends on the surface style setting you're using when you run the export command.  You could also export the contour labels if you want to show the elevation of the flattened polylines.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
sboon
Message 2 of 3 (136 Views)
Re: exporting contours from autocad civil 3d to autocad
04-10-2014 10:35 PM in reply to: THEBOLT
Steve
neilyj
Message 3 of 3 (131 Views)
04-10-2014 10:45 PM in reply to: THEBOLT
But please don't pass these on to anyone who needs to recreate the surface...... export the surface as an XML or extract the dtm triangles and WBLOCK them instead.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
