hey,
i want to export civil 3d contours to autocad but flattening the contours and still defining the elevations of of the contour. is this possible ?
thankyou
Solved by neilyj666. Go to Solution.
Solved by sboon. Go to Solution.
You can export the contours with elevations, or flattened to zero. What you export depends on the surface style setting you're using when you run the export command. You could also export the contour labels if you want to show the elevation of the flattened polylines.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
