I Can't think of what might be making this happen, but when I export a single layout to PDF (or to a printer) everything works out as normal. When I Export all Layouts to PDF, my text changes fonts and inserts squares for only some of the characters. Any ideas or help would be greatly appreciated!
How do you do that? Using command _EXPORT or command _PUBLISH?
If _PUBLISH then what pagesetup have you set?
- alfred -
have you tried _PUBLISH ias alternative?
- alfred -
Does the Publish report show the proper profile being used? In some circumstances I've seen Publish fail saying "Can't find CTB (blah.ctb)", because the profile listed wasn't the active profile. Not your immediate problem, I know, but its the only thing I can think of.
