Hi ))
How can I Export civil 3d file to another civil 3d file??????
or import..... do the same.........
Are you kiddin' us, Charlie?
You can use either the _INSERT command, or _LANDXMLOUT a surface of the first DWG, then _LANDXMLIN it in the second one.
If want a copy of the drawing use SaveAs. If you want the whole drawing in an existing drawing use Insert. If you want a portion of one drawing in an existing drawing either use Wblock and Insert or Copy - Paste.
Allen
Allen Jessup
CAD Manager - Designer
Thanks for all advises
In my file I have problem with cross section view marks(to see on picture), that why I want insert this file to another file where it is ALL right ............
neilyj (No connection with Autodesk other than using the products in the real world)
I agree with Neil. You either need to change the scale on your destination drawing or change the style to one that is appropriate to the scale of the new drawing.
Allen
Allen Jessup
Tank you, I changed the scale on my destination drawing.It is the easy way for my question )
