Not sure if this would be an appropriate place to ask this question. But does anyone know how to get a Trimble friendly surface for DTM staking out of C3D for Trimble Access software. Generally Trimble is looking for a TTM file. I had tried to export a surface using an XML file but apparently this did not work.
Suggestions??
There is an addin from Trimble, or you can bring your LandXML into TBC and create a .ttm
Not sure what version you need, but this should guide you. https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Where-to-find-Trimble-Li...
Trimble data collectors will use xml files. Right click your surface and export to LandXML.
