Civil 3D Forum
Export to Trimble GeoXH
7 REPLIES 7
Message 1 of 8
1114 Views, 7 Replies
I am attempting to export a design drawing to my Trimble GeoXH.  I can't get this to work.  anyone have any suggestions?  I have installed the trimble link and have tried that.  It does not work.
7 REPLIES 7
Message 2 of 8
ToddRogers-WPM
What file extension do you need to export to?
Todd Rogers
Message 3 of 8
sboon
The GeoXH appears to be a mapping grade receiver.  Most of these GPS units can import data in gpx format, and many can use kml files also.  Check with your dealer or the manual, and then post here with details of what file you need to produce from C3D.
Steve
Expert Elite Alumnus
Message 4 of 8
in reply to: sboon
DXF is acceptable but I am getting a error message when I import my exported file, invalid file type.  I am not sure where to go from here.
Message 5 of 8
ToddRogers-WPM
Go to your Home tab, Create Ground Data Panel.  Click the flyout for Create Ground Data and select Survey Data Collection Link.  Once opened, click Transfer>Send/Receive.  There you can select the Trimble Data Collector.
Todd Rogers
Message 6 of 8
sboon
Most of the devices which accept dxf files only work with the older dxf versions.  Try exporting again to an R12 or R14 dxf file and see if that works.
Steve
Message 7 of 8
Thanks I will try that. Kurt Reno, CCM Kurt.reno@ch2m.com Cell: 719-238-0790 Office: 720-286-0746 9189 South Jamaica Street Englewood, CO 80112-5964 [cid:531342923@01122009-208F]
Message 8 of 8
Murph_Map
If your dwg has Civil3D objects in it export to AutoCAD foramt first, then export that with Mapexport to shp format. Unless they changed in the past year the Trimble GeoXH can use shp files and are georeferanced a lot better than the DXF format and also can hold data/attributes.
Murph
Supporting the troops daily.
Rail Community
