Civil 3D Forum
export to hec ras
16 REPLIES 16
Message 1 of 17
CityWF
6332 Views, 16 Replies
export to hec ras
For some reason I am unable to export to hec ras. I have followed the directions exactly and everything works like it should, even naming and saving the .geo file. Then it makes a .geo file with no info in it and the program locks up. Its still using the .geo file, you cant open it until after autocad is shut down and quits. I even watched the AU webcast to see if there was something I am missing. I don't know.??? I am running civil3d 2011. 64 bit with lots of ram. I don't think my computer is too small.
Thanks, any ideas are appreciated,
Janet - CityWF
16 REPLIES 16
Message 2 of 17
SethHall
in reply to: CityWF
Hi Janet-
Did you ensure that you had all the selections made in the "export to HEC RAS" dialog? For example if you leave the sample line groups set to <none> the geo file will still be created however it will be "empty" and not contain any data.
Seth Hall
Product Owner
Model Builder
Message 3 of 17
in reply to: SethHall
I am having the same problem. I'm using the 2012 version and have definitely selected the surface, alignment and sections in the export to hec-ras dialog box. This has been tried on three different systems using the 2012 software to no avail. Any ideas?
Message 4 of 17
Same problem here!
Brad
Message 5 of 17
Solution discovered.
Make sure you don't have a jagged looking alignment. In other words, your alignment needs to be geometrically correct. Smooth curves and tangents.
This fixed my problem! No more blank empty GEO files. 😛
Hope this helped
Regards
Brad
Message 6 of 17
Neilw_05
I have the same problem. The odd thing is it worked once but now it won't. I don't recall making any changes to my alignment. At least now I know that it is not due to some mis-step on my part.
I don't think it should be required by the software to use curves between tangents on the channel alignments. It serves no practical purpose with regard to the modeling process and just makes for unnecessary busy work. I have a lot of PI's in this alignment. I hope I don't have to add curves to all of them.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 7 of 17
BrianHailey
in reply to: CityWF
I had a client with the same issue. I think I narrowed the issue down to the fact that the surface that was being exported was created from a corridor. I created a new surface from the corridor surface, sampled that new surface, and it exported just fine.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 17
in reply to: CityWF
Has this been fixed?  I am getting blank Hec Ras output files too.  So frustrated.....
Ken
Message 9 of 17
in reply to: CityWF
In case anyone else runs into issues, here are two things I have found while exporting and importing.
1. Import the .geo as GIS Format. This is not intuitive, but it will make sure the data comes in.
2. Do not allow you alignment to extend past the extents of your surface. Doing so will cause the reach line to do odd things like appearing no where near your cross sections.
Have fun!
Message 10 of 17
fcernst
Oh, and flow direction and cross section stationing still come into HEC RAS  backwards from Civil 3D, in Civil 3D 2013. Smiley Very Happy
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 11 of 17
in reply to: CityWF
I was also creating empty .geo files when exporting from AutoCAD to HEC-RAS.  I think my silly mistake was creating the surface AFTER creating the sample lines, so the sample lines groups were not sampling any surface.
Message 12 of 17
wfberry
You just need to go back and edit your sample lines --> "sample more sources".
Bill
Message 13 of 17
Same problem, anyone found a fix?
Message 14 of 17
Hidden_Brain
the only times this has happened to me was when:
1.the reach centerline alignment extended beyond the extents of the surface it is sampling.
2. (if i remember correctly) if i did not select the correct site while on the export to RAS dialog box.
Message 15 of 17
david.dixon
in reply to: CityWF
In 2014 and 2016, I had to promote my surfaces into the current drawing for the .geo file to be written and saved.  Surfaces data referenced did not work for me...output was 0 byte file.
David Dixon
Senior Civil Designer
hdrinc.com/follow-us
Tags (1)
Message 16 of 17
in reply to: david.dixon
I'm running 2015 and I have tried exporting 3 times.  It makes the .geo file just fine.  However, when I import in to HEC-RAS I get an error that says I have cross sections outside the reach boundary.  I have checked them all three times and everything is inside the surface boundary.
Any suggestions?
Thanks.
Message 17 of 17
Hidden_Brain
do you have any hide boundaries on your tin that fall right on the alignment (reach)?
Rail Community
