Distinguished Contributor
TherealJD
Message 1 of 5 (356 Views)
Export to AutoCAD missing stuff
356 Views, 4 Replies
03-16-2010 11:40 AM
i've audited and purged the drawing prior to doing export, but i keep getting stuff missing on the exported file...
See before / after attachment. Any suggestions on what I could do, muchly appreciated.
Using Civil 3D 2009 -->export to AutoCAD 2007
Go back to 2010 and use AecObjExplode, and then saveas 2007.
Matthew Anderson, PE
therealjd wrote:
> Tried a recovery on the drawing.. and purged everything in the drawing. Still having the same issue...
> Tried auditing the drawing as well.. still missing the same stuff when exporting.
jefflambert9091
Message 2 of 5 (356 Views)
Re: Export to AutoCAD missing stuff
03-16-2010 01:47 PM in reply to: TherealJD
I had a problem with a drawing that would go through all the motions but not save the file. I found I had to recover the drawing, purge Unnamed Objects and then I Purged All. It may be a shot in the dark, but FYI.
Jeff
Professional Surveyor
Cincinnati, Ohio
Civil 3D 2013
TherealJD
Message 3 of 5 (356 Views)
03-16-2010 03:42 PM in reply to: TherealJD
*Matt.Anderson
Message 4 of 5 (356 Views)
03-16-2010 09:46 PM in reply to: TherealJD
TherealJD
Message 5 of 5 (152 Views)
09-26-2012 02:59 PM in reply to: TherealJD
this worked.. thanks! :smileyhappy:
