Civil 3D Forum
Export shp file with layer names
3 REPLIES 3
2204 Views, 3 Replies
I need to export 3dpolylines from C3D 2013 to an ERSI SHP file.
Using the mapexport command I’m able to do this, however, the lines in the shp file don’t retain the layer name and colours that are in the C3D file.
Do I need assign ‘object data’ (or something similar) to the 3D polylines before exporting the shp file.
Thanks in advanced for any help.
3 REPLIES 3
Alfred.NESWADBA
if you started _MAPEXPORT, you first have to select the filename and in the next dialog go to the second tab, there you have a button for assigning attributive data ==> choose layer or whatever you want.
Be careful, if you export the color of an AutoCAD entity you might get "byLayer" and not "red" or "green" 😉
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Ajilal.Vijayan
Please follow below steps while Exporting and Importing the Shape files.
I found this only keeps the layer name NO COLOR
in reply to: Ajilal.Vijayan
Excellent, it works!
Thanks for your help
Rail Community
