Civil 3D Forum
Export Section information to .CSV
2 REPLIES 2
L0uise
766 Views, 2 Replies
Good Morning,
My Engineer has a Hec-ras file that he has been working on and I need to change some of the sections. I don't want to re-export all of my sections to a .goe file and lose the work he has already carried out.
Is there any way of exporting the necessary sample line information into a CSV file, as I believe this will be the best way to make the changes to the hec-ras data without losing the work which has already been carried out.
Any help with this would be greatly appreciated.
Kind Regards
Louise
2 REPLIES 2
KirkNoonan
in reply to: L0uise
You can select the section line itself, list it, and copy the station / elevation values from the command window and paste them into your spreadsheet.
ad.bakker
in reply to: L0uise
you can use "task pane" then use query, and filter the lines you want to know. You can make a report doing that save with the extention .csv and youre done
if you need help making it so let me know
Rail Community
