Could someone take a look at this. This is only a tiny portion of my drawing.
I am trying to export these points so I can create a new surface in a new drawing.
The points in question have coordinates and elevations but I can't seem to export them.
Does anyone have any suggestions on how I can do this?
thanks,
Solved by Jeff_M. Go to Solution.
Stephen,
You don't have any COGO Points in your drawing, just AutoCAD Points. There's a difference. You can turn them into exportable COGO Points thusly:
Dave
Dave Stoll
Las Vegas, Nevada
Stephen,
Oops, my way won't work. Follow Jeff's suggestion.
Dave
Dave Stoll
Las Vegas, Nevada
Jeff_M
The file I attached is only a tiny tiny portion of the drawing. These autocad points are for a full town in which I need to extract. Would they be just as accurate as if I brought them in myself and would you suggest creating a surface this way or is there a way to import contours online to Civil 3D 2015.
Stephen,
"When I create a surface and add points to it, it tells there is no points found in the drawing."
Can you elaborate a little on this? How about a Screenshot of the problem. Does the problem occur before or after adding points to the surface?
Dave
Dave Stoll
Las Vegas, Nevada
Right, as I said in my first reply, there are no points. You have blocks at elevation, so use the Drawing Objects option to create the surface:
