I'm running C3D 2013 and want to export a point cloud to ASCII format. When I select, then right click my point cloud, I don't get the option to "Export Point Cloud". Any ideas?
To export point cloud data to LAS or ASCII formats
Hi Nick,
In order to export Point Cloud, you may want to go to Points in the Menu bar | Import/Export Points | Export Points | Select the format | Provide the destination directory | Click OK
http://screencast.com/t/YNwv2IagC and http://screencast.com/t/akDCOQTx
If you do not have the Menu bar shown, type in _AeccExportPoints in the command window and press Enter key.
That does not work. My point cloud data is an LAS file. I wish to convert it to a csv or txt file. Any ideas?
ragsdale496 wrote:
Any ideas?
Maybe, sir.
Please upload that .LAS on a file sharing service e.g. http://ge.tt - we'll try a couple of techniques and let you know what it's all about.
If you need it quick you can download RECAP http://www.autodesk.com/products/recap/get-started
You can import the LAS file and export a PTS file.
Allen
Allen Jessup
CAD Manager - Designer
More or less. I will need to filter the LAS file before I export. I only need bare earth and water classification points. How did you perform the export?
I used the opensource Qgis, sir, whilst I fear there's no Autodesk software able to classify a point cloud (hoping I'm wrong...)
