How do I get the export parcel ananlysis to show degrees minutes and seconds instead of the default decimal degreees. My direction settings are set to DMS, but I can't see where to change arc deltas...
I've set the Parcel analysis format to Degree/DD.MM.SS, set ambient settings to Change Commands, saved both but still the report shows curves in decimal format.
That sounds correct. Have you checked for an override in Toolspace>Settings>Parcel>rightclick-"Edit Feature Settings"> Angle?
