Civil 3D Forum
Export lines as shapefiles to ArcMap
6 REPLIES 6
ozaukeelandwater
1540 Views, 6 Replies
I am trying to map export shapefiles to arcmap, but it keeps telling me export did not succeed. Any suggestions?? Thank you.
6 REPLIES 6
in reply to: ozaukeelandwater
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13251791&linkID=9240697
This may help. There is another I don't have time right now..
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Are they basic AutoCAD lines or Civil 3D objects?
Murph
http://map3d.wordpress.com/
"Ozaukeelandwater" wrote in message news:6305119@discussion.autodesk.com...
The lines are polyline (2D polyline).
File location and name, set the file location close to the C:\\ not buried
in a wad of subfolders, give the file a simple name like ABC.shp
Then of course you read John Mayo's reply right, and you are selection line
as the type of export and selecting objects not on a locked layer. What
attribute information are you exporting with the lines? Is the dwg a newer
dwg or a old dwg that's been around for years? Are the polylines lwplines?
Might try running the convert command if they are the old style polylines.
Murph
"Ozaukeelandwater" wrote in message news:6305376@discussion.autodesk.com...
Hi there:
John Mayo's referenced post (http://usa.autodesk.com/adsk/servlet/ps/dl/item?si​teID=123112&id=13251791&linkID=9240697) could not be located in the Discussion archive. I have a post on the Autodesk EduComm board regarding interoperability of Student version Civil 3D and ESRI ArcMap via widget from ESRI. Is aforementioned reference still available?
Thanks from a newb to the boards. -- Mark
eladkcem
Not sure why, but I got the same error message late this evening...
moving my target directory close to c:/  solved the problem...
Thanks murph.
-d
Rail Community
