I am not 100% sure this is why, but I find that importing an alignment thru
XML always applies certain constraints regardless of how the alignment was
created originally. LandXML doesn't know or care what curve constraints you
used when you first made the alignment. if I remember correctly, they all
come in as fixed curves which limits what you can change.
Dana Breig Probert
http://civil3drocks.blogspot.com/
http://groups.yahoo.com/group/cadapult_civil
"Darius" wrote in message
news:5172605@discussion.autodesk.com...
Hi all,
I have a problem when I export my aligment to xml and import in new drawing
I can edit values in aligment geometry values table, in original aligment I
can do it for examle edit transition curve lenght,
where is the problem?
thanks
Darius
