Solved by Harold_Alberto. Go to Solution.
cross seciton is base on the surface. since the data you will get when you extract the cross section is bsae on the original surfac.
One solution I can think is you make a new surface.
first, you put points every 10 meters from the center alingment extending out left and right of sample line.
second group you points and make a new surface out of the new point data.
then use the new surface to creat your cross section.
by doing so you will get the desire value ever sectin when you export the data.
hope this help you...
cheers
alc
I'm not sure how to get the data in exactly 10m intervals. But to export the data first create your cross section. Select the cross section (the section itself, not the grid). Right click and choose 'edit section'. This will bring up a window with your section data. Right click in the window and select 'copy all'. You can then paste this data into excel. Good luck.
this lisp can export cross section point from civil 3d . for run lisp type haraz3d in civil 3d. help for working with lisp show after run.
all section data save in civil 3d file location. for more information send mail to kheradirad@gmail.com
https://www.rapidshare.com.cn/jus42qE
you can see in youtube AutoLISP program for this.
Sir how to export 1 meter interval data ?
Plz help me sir :bouquet:
I request to plz send me any lisp
tsmrizwan@gmail.com
If you try to see the answer on 12-18-2017 11:20 AM you can download the appropriate lsp file.
you can download haraz3d.lsp from following link: https://usaupload.com/2A0M https://gofile.io/d/CsrNWU
or email me: kheradirad@gmail.com
